BFG Ko2’s outdated?
JefeAZ
Tucson
I believe the KO2s are getting replaced soon. I signed up for this group email through BFG a while back and they send me surveys to fill out. I got one on Sept 13th and it was all about how to market offroad tires and what category to put them in. I should have screen-shotted the slides as it had pictures of some new offroad tire designs and asked me which I liked more
jzweedyk
Moab/Winter Travel/Summer Travel
There's only a 470 lb. difference between the Gen1 and Gen2 if memory serves me correctly.
I don't know why someone would even buy the C tire for any year.
Unless saving $160 for a set is a big deal to someone.
I'd rather have a stronger sidewall for airing down and puncture resistance
A C range tire is much better for off road. Most of the big tires (40" and above) are C range. The sidewall is much more flexible to be able to wrap around rocks and grip better. You only need to go to a higher range tire if the weight of the vehicle is too great for a C range. As far as sidewall strength, the C range is fine, and the fact that it flexes more means less likely to be cut by a rock. I won't say it couldn't happen, but I do not believe an E range tire would be less likely to get cut or hold up better. If I have a choice I will always get a C range tire, and money is NOT the reason.
Pikser
Available in stock in Houston. Both NTB, Discount Tire and most Ford Dealers
GCATX
King Dingaling
Central Texas
Truth.
Joe12345
PA
Ever since I started driving jeeps I’ve always put e rated tires on because I like the stiffer sidewall on road. It hasn’t impacted the off-roading at all, but I don’t do the crazy trails in the local terrain parks.
I’ll probably be switching out my factory ko2’s for E rated Cooper STT pro’s in the near future.
KTag98
KTag98
Missouri
that’s really interesting actually. I wonder if maybe the pictures you saw were actually their race tires though?
JefeAZ
Tucson
Not sure but they looked fairly tame compared to KM3s. Looked like a street/offroad combo. I clicked the link again and it wont let me jump back into the survey. Heres what I get every couple months. They usually give me a $10 Amazon card. Cant remember how I got signed up for it. You can try to sign up here: https://bfgoodrichpanel.opinioninsight.com/portal/community_1_2_1.php
KTag98
KTag98
Missouri
well. It’s invite only I guess, so I can‘t jump in there and try to get that survey going on my side. Does make me curious though.
