BF Goodrich KO3
Heinz
California
Currently getting KO3’s on my Gen 2. Also worried about the F load rating and added weight but figured I will try them out. Will report back once I put some miles on them.
I’m coming off of the C Load KO2’s so will have a direct comparison.
encyphor
Eagle, ID
Damn, I need new tires as well with 40k on my KO2s heading into an Idaho winter. I'm really torn between putting KO2s back on in OEM C-rating vs. going KO3 with the F rating. So far from those that have put it on, it sounds like F rating isn't an issue, but would like to hear your initial thoughts once yours are on - the more consensus the better. Do you have them installed yet?
bigkatR
Houston
I have 4000 miles on a set of KO3's including a 1800 mile road trip. Side walls are a little stiffer than my KO2's. I like them except its hard to compare with 40k on my previous tires.
Heinz
California
500 mile update with the KO3’s (F Load) which I had installed two days ago. I’ve had a bit of everything to test them on - highway, snow, dirt roads, mud.
I have run at 37psi all around with the intention of lowering incrementally until I find a sweet spot.
Prior to this I had run three sets of the C Load KO2’s and personally they did well enough for me that I didn’t find a reason to change. My use of the truck is: 1) daily driver, 2) ~20 trips/year driving through the California desert and mountains chasing quail and chukar, 3) ~12 snow days/year in the California and Utah mountains. I would say everything below is pretty much to be expected, but maybe a helpful for those who have also liked their KO2’s but are considering a swap.
Stiffness: KO3 F loads are noticeably stiffer. You feel more small vibrations on road when going over cracks in the pavement. Off road, the washboard is harsher. If the truck came this way though, I’d probably never know the difference. So, I’d say it’s “fine”, but coming off 80k miles on the C KO2’s, I miss the softness. I’m hoping if I get down to 33 or 34 psi it will be slightly better, we’ll see.
Noise: Quiet, like new tires are. Can’t say they’re any different than new KO2’s.
Dirt roads: A little loss of traction on the washboard due to the stiffness. This is where I really missed the C loads. Here’s the best comparison I can make - imagine running washboard roads on C Load KO2’s at 45 psi.
Snow: Honestly, I was impressed. We got a foot of snow in Mammoth, CA. Snow driving was a combination of a short unplowed driveway, partially plowed roads/parking lots, and unplowed roads with ~4” of fresh snow. I drove around the neighborhood which has some pretty steep grades, where I would have expected some slipping from any tire. I intentionally got on the throttle to try to get them to slip and in 4H the tires hooked up nicely. For comparison, my buddy in front of me was running Falken Wildpeak AT3’s on his Ram and he did slip a little in 4A. I did the same roads again in 2H and the rears got a little loose going up the grade, but fully manageable. I think the KO3’s are noticeably better than KO2’s in snow from the limited time I’ve had them on.
MPG: This might be my biggest concern so far. I’ve averaged 13.7 (my own calculation). But this is with a lot of highway driving where I’d usually average 15+ with the C load KO2’s. I want some more time to really get a sense here (road from SoCal to Mammoth has a lot of grade and a headwind), but the truck does feel slightly more sluggish with the extra weight in the tires, in my opinion.
Bottom line: I am eager for C or D load KO3’s. I think they will be an improvement over KO2’s. However, gun to my head right now, I would say stick with C load KO2’s if you like them. I would switch to the KO3’s if you do a ton of snow driving or if you don’t think you care about the slightly stiffer ride. But then again, if you want to optimize on snow, there are other tires to consider too that aren’t an F load rating.
encyphor
Eagle, ID
Thanks for the detailed writeup @Heinz!
I was leaning towards putting another set of KO2s back on while awaiting the C or D release from BFG in a year or two. While the improved wet and snow performance is intriguing for Idaho winters, I never had an issue or felt unsafe on KO2s in the snow/ice - slow it down, no tire is magic or going to outperform studs.
KO2s being slightly cheaper, time on dirt/washboard roads, KO2s are probably the best (for me) at this moment given the availability of only F rated KO3s for now.
dsiggi
Guest
I love the C rating K02. I hope they come out with similar K03. Imagine something will happen in next refresh of F150/Raptor. Many of my friends trucks run E rated K02 or others as E rating is mostly whats available in our size. I just really like the look of the C Rating, the tread patch is wider, and when i air down its softer. Remember the OEMS work with tire manufacturers to develop specific tires for the vehicle. This is especially true and more important on performance vehicles.
Heinz
California
Ya I’d say if you’ve liked them, stick with them for now.
One thing I forgot to mention - I asked the guys at the tire shop how the KO3’s balanced compared to KO2’s and he said they were easier to balance and required minimal weight. I never had trouble with my KO2’s not being balanced, but the guy at the shop said they can be tough, and that the KO3’s were better. This might be anecdotal at this point, but I know it’s been said that BFG had tried to improve this with the KO3’s.
thatJeepguy
GA
F load is ridiculous. Either go with something else , or put c ko2’s on. Either way just wait.
someday
wisconsin
According to BFG KO3 315/70R17 C are not being made but a D next year. Either ford is going with a different size (thought nothing in the KO3 ~35" R18 C range in the works), manufacturer, same KO2 C if BFG will still make them, or 37 standard for gen 4 (KO3 37x12.50R17 C in 2026)
