Beyond 37's
Netix
Banned
Ontario, Canada
What about 38's? 39? maybe 40's?
Even with custom modifications and alot of grinding ect would it be possible to run 40's?
What did they do with chris ross truck ? they installed 39's i believe.
heres a vid of a eco boost with 40's
Nitto Tire Mud Grapplers - Ultimate Adventure 2011 Part 2 - YouTube
Im getting 37's next week, going to chop the inside wheel liners ect anyways... just thinking if i could go .... even... bigger.
justvettn
GTA
Chris has 39's and they don't look overly big on his truck so its possible with a lot of work no doubt. Some 4X4's running TR's in that video.
Did you get a chance to measure your backspacing?
Bigg50
Benicia, CA
I would think you'd need to move to some sort of long arm kit and get fenders. I don't know how well the stock suspension would handle the size of 39's or 40's. For a street queen I'm sure it would be fine.
justvettn
GTA
I don't think long travel makes your truck sit any higher then top perch?
pat'sRAPTOR
Everywhere
I have 37" toyo MTs and at full turn I'm like CM away from rubbing against my rpg 1.5" UCA's but the toyos are over 14 inches wide with the lugs on the side. I run methods with a 0mm offset so if you stay with a UCA's that isn't bigger then 1.5" cup and you run say maybe a -3mm or bigger offset then you could maybe run 39's with cutting the fenders up or going glass.
pat'sRAPTOR
Everywhere
What size is the cup bearing on the ADD UCA's?
Yea you'd definitely need to regear that hit haha and gas Milage will go out the widow.
