Best wiring.
Yukon Joe
Trafford, PA
Place a circuit breaker on the feed cable to the marine fuse block.. I prefer a circuit breaker there so if it trips with the shorting of a fused circuit I am not fumbling to find the fuse for it...
That's an interesting idea. I have a large amp fuse I used. Bought a spare fuse for $3.
Do you have an example of a breaker? Are they water proof?
Yukon Joe
www.RUNRAPTORRUN.com
Captain Awesome
Alberta
Yukon Joe
GREAT LAKES RAPTOR EXCURSIONS
285-Series - Blue Sea Systems
images
JJ f150harley
JJ f150harley
Traverse City MI
Ice I am going to place a breaker, maybe. Joe I will show you the box when I get home. Doing just like mas up fitter thread. Captian thinking of using that. Put one on the boat in December for the jl audio and it works great.
Sent from my DROID RAZR HD using Tapatalk
Captain Awesome
Alberta
it's funny cause i was just talking to a friend about them this weekend. when i add more switches i will be using one.
as for wire i've been using this stuff for years with no problems and if i need to run 2,3 or 4 i use this.
Grote Industries: 2,3,4 Conductor PVC Jacketed, General Thermo Plastic Wire (Product #82-5509)
Grote Industries: Primary Wire - General Thermo Plastic Wire (Product #89-3000)
JJ f150harley
JJ f150harley
Traverse City MI
Captian I can tell you that those work well and that it made my wiring look way cleaner. I would recommend west marine or a marine wholesaler to get them. Thanks for the wiring.
Baja thank you gonna take a look tonight and then find what size.
JJ f150harley
JJ f150harley
Traverse City MI
Here is the fuse panel I'm gonna be running. I'm doing like the thread mas factory upper fitter switches. The positive is on the bottom and the negative is on the top with the 12 screws. I think it should work well and I plan on running relays. Should work well. Thanks to everyone for the great advice.
The Car Stereo Company
here, on frf
depending on what you plan on running, you shouldnt need relays. if your power going in is big enough, you can connect whatever you want there. a standard automotive relay is 30 amps. some are 40amps. but the atc fuses are safe to 30 amps with the right wire. (i have seen 40 amp fuse melt on numerous occasions, so i prefer to stick with a 30.) if you are drawing more than 30 amps, then you should use a different kind of fuse. but i dont think relays will be necessary unles you got some wild plan for your stuff.
JJ f150harley
JJ f150harley
Traverse City MI
thanks Busa. i am going to be running 5 sets of baja designs lights, 3 rigid reverse lights, compressor switch, switch for my train horn. I will be running max fuse of 30 amp. I might run relays for the lights just to be on the safe side:)
Busa quick question: should i run 0 or 1 gauge wire to behind the rear seats to a distribution block, then run 1 or 2 gauge to this fuse panel? I will be running 2 amps for speakers and subs in the future. thanks
