Best Intercooler for Stock Location?
RW17FX4
Is it plug and play and much larger than stock?
I’m also running the CVF intercooler. Jason from CVF was very helpful and answered all my questions. I did have to remove part of the factory intercooler shroud, just pretty much a “trim piece” so to speak, it popped right off. The actual intercooler shroud and shutters etc, all stayed in place.
Donovan
DC
Good deal.
But these aftermarket intercoolers should be larger or deeper to be useful correct?
RW17FX4
Good deal.
Jason from CVF or someone much more knowledgable than myself will be able to clarify this. there are multiple factors that contribute to a more efficient and more free flowing unit
CVF-Jason
South Florida
Sorry for the delay - I was accidentally keeping an eye on the wrong forum (1st gen.) so I missed these questions. Oops!
It is plug and play, and very much so larger than stock (slightly over 50% more core volume to be sure at 20.5 x 4.5 x 9).
Good deal.
Not necessarily. Now, in simple terms larger is generally better for intercoolers, but as I recently responded in a PM there's three facets to an intercooler (not in order): your end tanks: computer-aided and cast is generally better to facilitate air flow in and out of the unit - you'll find cast end tanks on all the major manufacturers, your size: again, larger is generally better but you're restrained by size in front of the bay and how much modding you want to do to fit your unit - not to mention diminishing returns as units larger than stock replacement are more expensive, and the most overlooked, which is quality of the core: you want a balance between density (fins packed together) and size to facilitate airflow - you also want it to be staggered for better cooling. Bottom line, it's an equation of all three.
Our value proposition is simple: proven 40+ degree reduction (data on the product page), minimal difficulty of installation, and we try to give the best support possible. And we're a state-side outfit out of Miami.
Hope this helps!
CVF-Jason
South Florida
Kirby Lastinger
Lakeland, FL
So the CVF Intercoolers requires no cutting of any parts or supports, keeps the stock fans, louvers, and shroud on the raptor?
