Bedrug, Bakflip, and Bakbox Installed! Pics!
Phyguy
Denver, CO
I really don't see a problem with mine falling in with how I sized it up, but if it ever did, it'd be a quick fix with drilling 2 little holes on each corner to tie the brackets to the tonneau rails. I could even do a quick release style pin for faster removal.
Cool. Let us know how it goes.
Blukrom
Cerritos CA
Reptar, question on your bed rug and tailgate extender. Did you end up cutting holes for the locking pins or just do the X thing over them so they could push in?
By the way good tip on using the long Velcro on the bed sides by the tailgate, much better than the small chunks per the instructions.
Jeff
Reptar
Reptar
Jersey
I used a fresh blade on my razor knife, and cut the holes for the bed extender locks. I just pushed in with my finger to feel where the indent was for the hole behind it, and carefully cut the hole. It was slightly smaller diameter than the actual hole, and not perfectly round, but enough material removed, that the factory plastic inserts could still be reinstalled. I had to use a plastic deadblow hammer to get the plastic inserts back in though, they took a little "whack" of the hammer to compress the bedrug and allow them to snap in.
I did the same for the bed extender bolts. Cut a small circular hole for the bolt to go through. I didn't want to do just the "X" cut and have it getting caught in the hole for that large bolt. I may take them off again and add a washer to space each side inwards a bit, they're really snug against the bedrug sides when I rotate the extender in or out.
Blukrom
Cerritos CA
Oh so you pulled the plastic grommets out. I was thinking about that but just left them covered for the moment, was thinking about leaving them and not bothering with the locks. The extender was very tight on mine too, I just backed the bolts off a little and that helped. They are still tight but not as tight as i would like, I will keep and eye on them.
On the BAKflip, it rattles against the cab when driving while open. I found that out when I moved some furniture yesterday with it open and locked up. So I took two pieces of that half round rubber they provide for shimming and stuck it to the bottom side of the BAKflip where it touches the rear window when all the way open. Worked as a nice bumper.
Reptar
Reptar
Jersey
Yeah, it's kind of sloppy IMO if you just cut holes and leave the grommets behind the bedrug. Then you just have holes or slits in the rug. Putting the plastic caps back over top really finish it off to look OEM. I'll get some pics of mine all reinstalled, I think you'll decide it's worth the little extra work to reinstall them over top the rug. Plus they also help keep the rug in place at the tailgate and really secured in. They're a little tricky to remove, but some blue tape to keep from scratching the paint, a putty knife to start lifting the edge up, then a flathead screw driver, and they pop right out. Feel and cut the holes, then a deadblow to pop them right back in fully clipped and seated over the bedrug.
I don't use the locks either for locking the extender in the bed, but when I flip it out on the tailgate I will. And I originally left the side bolts not as tight so it wouldn't clamp against the bedrug as tight, but then the bolt heads would rotate, and typically only rotate on the loosen direction, and not on the tighten direction, so over time they'd eventually really loosen up. So I tightened them till they wre locked in place to not rotate. I noticed factory put lock-tite on them so I'll probably add a washer under each side, and lock tite them on reinstall.
My Bakflip came with 3 pieces of rubber about 1' long each, taped to the bottom of one of the panels. About 3/8" wide and 3/8" thick. At 1st i wondered what the heck they were, then I realized. Those aren't for shims, the f150 version has the preinstalled shims. They are for the panel against the cab when open. When its open against the cab, it's just the hard metal hinge against the rear window, and driving with things moving it would scratch up the surround. So I put those 3 pieces of rubber along the edge of the panel where it would touch the cab, 1 in the middle and 1 on either end, and it worked perfect. Now it's got cushion for any flex and vibration to not harm a thing, and when the cover is shut they're on the bottom side so it's in the bed and you never even see them.
What is the benefit of the plastic drain tubes for the bak flip? I don't have mine on
So whatever water that runs down into the channel will drain through the tube and out of your bed. If you don't have the plastic drain tubes connected, water will just run into your bed rather than through the tube and out of the bed.
Reptar
Reptar
Jersey
yeah drill holes through the plastic inserts in the front of the bed, they pass through to the exterior, and run the tubes through there.
CAbimmer
DFW
Do they offer a discount for FRF members? Getting ready to order my bedrug and F1. Truck gets here in about 3 weeks
