bed stabilizer how-to
Txfight00
Scottsdale,AZ
Pat did you cut out the bed bolt area more? Spoke with TMX on the phone regarding the bending issue and they said with lined beds, they recommend cutting out a little around the bed bolt to make the bracket sit flush. Looking good!
pat'sRAPTOR
pat'sRAPTOR
Everywhere
That's Exactly what I did! I mentioned that to Jason when the bending issue first came up cause when I got the test set I laid the lower bracket down traced it with chalk and cut the bed liner out is it sits flush with the bed metal on metal.
pat'sRAPTOR
pat'sRAPTOR
Everywhere
I have the drill but size listed in the first post in here I made a list of everything you'll need it's really simple I had my wife do the left side while I did the right so if she can do it anyone on here can lol
TMX Engineer
Yea that should fix the issue. Strafe's pictures are abnormal from what we have seen in testing. We will work to get those replace and get them back to the shop and analyze them.
strafe
Calgary Alberta Canada
Thank you for the quick response and I will get them back to you as quick as possible. I have been told many times how abnormal I am so it is not surprising. Otherwise still a great product and great support!
