Beautiful Texas Afternoon
dataustin
dataustin
Thanks guys. CineSLR, using that photo as an example could you explain the concept of the "rule of thirds" once more?
CineSLR
Roaming Shutterbug
New Orleans, LA
So the "rule" (ok suggestion, I like that) of thirds is a set of imaginary dividing lines that break the frame into three sections vertically and three sections horizontally. Think, tic-tac-toe board. You then take those lines as suggestions on where to place the focal point (what you want your viewer to look at). What this does is prevents the subject from being to centralized while same time leaves breathing space from the edge of the frame. It also gives the image a sense of purpose, like you took the time to place the car where it is in the frame, instead of slightly off the middle etc etc...
Like so...
Is this starting to make more sense?
treypal
Lord of the Raptors
Riviera TX
Not a great pic, but I try to do the rule of thirds usually. A lot of the new canon point and shoots will bring up the grid on the lcd.
