Bead lock ring removal or not?
Monte87
NY ******
Hi Guys-
I bought a set 2023 of 37pp raptor R wheels and gonna use w my 35 truck.. I love the look of those 37s way better than 35 wheels. Question, when swapping tires to new wheels and balancing them, should i remove bead lock ring?? I don't want the ring damaged.. Not sure what to do.
Thanks Anthony
catinthehat85
Socal
If the tire shop mounts and removes the tires from the opposite side, there is zero risk to rim damage. Every tire shop that does trucks all the time knows this. Make sure the shop has experience with trucks, a regular tire center like costco may or may not be able to get the tires removed and/or mounted due to the added thickness.
pat247
Oklahoma
If the tire shop has a modern tire machine that utilizes plastic pieces for tire removal it can be done without removing the beauty ring. I used my local ford dealer that had one of this type of tire machineon 9+ tires and not a single scratch leaving the rings on. Tried to save money when I purchased the 3rd set of tires, went to a small tire shop to get the tires mounted, asked before hand about the rings and was assured they could do it. Long story short, they scratched and scraped all four rings and some of the bolts were damaged by wrong size bit being used. Be careful with who you trust doing the work.
Monte87
Monte87
NY ******
Got it! Thanks so much!! I will make sure..
Anthony
Monte87
Monte87
NY ******
Pat, ty 4 reply and for sharing your story!!! I will ask my local guy if he does alot of trucks. He has a specialty shop, so im assuming YES!! But will make 1000% sure. or just remove the ring and reinstall myself afterwards.. Can we remove and reinstall later on with no issues?
Anthony
Donmatteo
Santa Clarita / Coronado
If they talk them off, they need to be balanced with them on. I know this for a fact as a shop did my 19 and they balanced with them off and the truck shook at anything above 35 MPH. They were WAY out of balance when they rebalanced with the rings in place.
CleverGirl_
Cabin Clown
this x100
Its a rotating assembly and it needs to be accounted for.
