Baja Mode
Woolaroc
Oklahoma
Was doing some dirt road cruising in Baja Mode yesterday, which I've not used before and noticed on my dash the the Turbo gauge never moved. I got to a high way and kept it in Baja but changed to 2x4 and could see it go to about 1/4, not sure of the PSI b/c I didn't have that display up. Is this normal for Baja Mode, does it not engage the turbos as much?
Also, this may be normal and I know it holds the RPMs higher before shift, but I'm about red line little over 7k before it shifts.
Yes, this is normal. Baja holds higher rpms and boost so that when you are transitioning throttle you are back in the power band sooner.
Woolaroc
Woolaroc
Oklahoma
But if it’s holding higher boost shouldn’t I see the Turbo gauge registering a reading? It’s not showing anything 90% of the time and I don’t hear the turbos.
VelociRap
Personally i don’t like Baja mode, when running offroad track (unless muddy) i use RWD, TC off and manual shifting that way i have full control and you have to high rev unless you are doing sightseeing :)
Booth9999
Idyllwild
Does it feel like there is power? With out the turbos it would fall on its face and really barely get to 50. I have used Baja a bunch in the sand but did not look at the gage. The truck it super aggressive in Baja, it seems like it would be noticeable....
GCATX
King Dingaling
Central Texas
I read somewhere, probably on here, that the only 2 modes that give full power are normal and sport. Not sure what net affect that would have on boost, but may be what's going on.
pbtjrlmrt
Oregon
As others have said...If you're not seeing anything registering on the boost gauge then you should also notice a substantial loss of power. If power is good then it might be a sensor or gauge. If power is off then one possibility would be that you have blown one of the hoses connecting the turbos to the IC. This actually happened to me after installing the AFE bladerunner IC. The clip holding on the hose fitting came off and the boost pushed the hose off. I immediately felt the loss of power and barely had any boost reading. Reattached the hose and all was good. Btw...I could tell the hose was off because with the windows down starting from a stop and flooring it I could hear the rush of air escaping the IC.
Booth9999
Idyllwild
I don’t think that is accurate.
Woolaroc
Woolaroc
Oklahoma
Did a little testing this weekend and had the wife take some video of the dash.
From a sitting start and about 1/2 to 3/4 throttle. I didn't smash the gas.
This was in 5th gear and the Turbos really started to respond no matter the throttle input.
I've noticed that if I don't SMASH the gas on the lower gears there is no turbo input and power is very low. If I go full throttle on the lower gears I do get turbo. Perhaps this is by design but Baja mode from gears 1-4 is lousy for power if you're not stepping on it HARD.
