Baja Designs - S8 LED Light Bar - NEW Products !
Baja Designs
www.bajadesigns.com
Baja Designs latest LED light bar comes with a few new perks! Enjoy the clean aluminum frame with 4,000 lumens of pure power, low amp draw of 3.33 amps, and nearly 50,000 hours of LED life. The S8 also features upgraded reflectors, an amber backlit feature, and new scalloped housing design. The S8 is backed by our 30 Day Satisfaction Guarantee and Limited Lifetime Warranty giving you the ultimate in purchase protection!
S8 LED Light Bar - starting at $329.00
https://www.bajadesigns.com/products/s8-LED-Light-Bars.asp
40W/4520 Lumens
Patterns: Spot, Driving/Combo, Wide Driving, Work/Scene
Light Colors: Amber and White Colors
Backlit Color: Amber
We also have the following accessories available:
- Black Rock Guard - $14.95 ea
https://www.bajadesigns.com/products/S8-Rock-Guard-Black.asp
- Amber Rock Guard - $14.95 ea
https://www.bajadesigns.com/products/S8-Rock-Guard-Amber.asp
- Clear Rock Guard - $14.95 ea
https://www.bajadesigns.com/products/S8-Rock-Guard-Clear.asp
Wiring Harnesses:
- On/Off Only - $24.95
https://www.bajadesigns.com/products/onx6-s8-xl-pro-sport-harness-2-light-max-150-watts.asp
- On/OFF + Mode (Amber Backlit) - $74.95
https://www.bajadesigns.com/products/s8-ir-wire-harness-w-mode-2-bar-max-325-watts.asp
-Bailey, Baja Designs
www.bajadesigns.com
donk_316
Edmonton
Morning Bailey,
Just about to wire this beauty up and then started thinking that I might be able to wire up the backlight feature to my running lights.
Has someone tried this before? Any insight to the wire I would attach the green wire to? Assuming the voltage would be correct.
Thanks!
Baja Designs
Baja Designs
Morning Bailey,
Thanks!
Hey!
You can definitely wire up the Backlit feature to your running lights. A common way of doing this is using an Add-A-Fuse or similar and tapping into the OEM fuse box underhood or in cab.
All you need to do is run the Green Wire from the S8 to the Add-A-Fuse.
Thank You,
Baja Designs
Baja Designs
S8 Lumen Count Update!
We've updated our S8 LED Light Bar and it now puts out 4,520 Lumens per 10" section instead of 4,000.
S8 10" LED Light Bar - 4,520 Lumens
S8 20" LED Light Bar - 9,040 Lumens
S8 30" LED Light Bar - 13,560 Lumens
S8 40" LED Light Bar - 18,080 Lumens
S8 50" LED Light Bar - 22,600 Lumens
www.bajadesigns.com
4x4TruckLEDs.com
Hey!
Thank You,
This is what we did on our demo truck. We probed some of the fuses in the fuse panel under the hood till we found one that came on when the truck was on. I then used a little tap-a-fuse and brought that into a custom relay panel I had put in my truck. This turns on 3 sets of amber bars (I used a relay because of the power needed).
So use a tap-a-fuse, bring that into a relay, relay goes to your battery/amber back lighting. Although with the amber back lighting only you probably won't need a relay just make sure your tap-a-fuse has 2 fuses (one for the main fuse you are removing, as it replaces that fuse, and the 2nd one would be for your accessory)
Baja Designs
Baja Designs
Don't forget! We offer the following accessories for our S8 LED Light Bar:
Wiring Harnesses:
www.bajadesigns.com
