Baja Designs S1 Reverse Kit Available at 4x4TruckLEDs.com
4x4TruckLEDs.com
4x4TruckLEDs.com
Great news for all you folks who have orders in with us... they are shipping today. We have plenty of stock on the Baja Designs S1 lights. Order yours over at 4x4TruckLEDs.com
4x4TruckLEDs.com
4x4TruckLEDs.com
We still have stock on the S1 (and S2) reverse Kits. Pickup a set while you can! These are hot items right now.
4x4TruckLEDs.com
4x4TruckLEDs.com
We just redesigned our upfitter connection kit and made it even better.
It's now an all-in-one harness so no more multiple harnesses to connect together. From your upfitter connection to the rear of the truck, you'll have one solid harness. The left/right light connections are built into the harness (so you don't need to worry about extension harnesses, splitters, etc...).
All you have to do (optional) is connect the included (with the reverse kit) Baja Designs Rear Upfitter harness into our harness and you're good to go.
Our harness connects to your upfitters under the hood, runs under your passenger side, plugs into the passenger s2 light, goes over to the driver's side where it plugs into that light, and then routes up to the driver's side tail light. From here you will plug in the upfitter harness that came with your reverse kit and tap it into your tails. DONE.
No more worrying about y-cables, splitters, etc...
You'll also love the fact that your factory reverse lights DO NOT come on anymore when you flip your upfitter. Our harness has a built in diode to prevent the factory reverse from turning on (throw some amber covers on them and hit up the trails without your factory reverse lights turning on).
And of course it's made of the same high quality components that our popular Triple Fog Light kits come with. Just another killer offering designed from the ground up specifically for our Raptors.
(If you've previously purchased the "old style" Upfitter connection kit from us, which consisted of multiple harnesses, PM me for a free upgrade to the new harness)
4x4TruckLEDs.com
4x4TruckLEDs.com
Our Black Friday sale starts tomorrow (12am EST). Be sure to pickup an S1 or S2 Reverse Kit for your Raptor. We're including our Upfitter Connection Kit FREE.
Unlike other kits on the market, our Connection Kit is a 1 piece design. That means less points of failure and an easier installation. You'll also benefit from our built in diodes that prevent your factory reverse lights from turning on when you activate the lights via your upfitter.
You'll also save $50 if you grab the S2 lights via a cash back rebate from Baja Designs! That's some awesome savings.
4x4TruckLEDs.com
4x4TruckLEDs.com
Our Upfitter Connector Harnesses are BACK IN STOCK. Due to the Black Friday craze we ran out briefly, but they are now back in stock. This harness is a $45 add-on for your S1/S2 kits (we also sell it by itself).
From the front of the truck to the lights, it's 1 harness. We're the only ones who offer a 1-piece harness right now designed for our trucks. We didn't want to have an upfitter harness plugged into an extension. plugged into a y-cable, plugged into a splitter, plugged into another upfitter. That's a lot of harnesses.
Also built into our harness are diodes that prevent your factory reverse lights from being back-fed power from the upfitters (important if you run your S2s with amber covers on the trails, you won't confuse other drivers).
You will still utilize the rear upfitter harness that comes with your S1/S2 reverse kit (optional of course). So that's the only thing you'll need to plug in should you decide to tap into your reverse lights. Otherwise you won't need to worry about messing around with additional Y-Cables or Splitters. Nice and sleek and simple to install.
Available here as a standalone harness OR offered with our S1/S2 reverse kits
S1 Reverse Kit: http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-s1-reverse-light-kit/
S2 Reverse Kit: http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-s2-reverse-light-kit/
Upfitter Control Harness: http://www.4x4truckleds.com/crystal...ness-for-2017-ford-raptor-s1-s2-reverse-kits/
scottro
Phoenix, AZ
Any pictures yet of the S1's installed?
EDIT: Sorry, should have searched. Most pics I see are with the bracket hanging below the bumper. Anybody cut a hole and manage to fit the S1's into the rear bumper?
