Baja Designs: General Discussion Thread - GEN 2
Baja Designs
Baja Designs
@Baja Designs is there enough room to fit a squadron Pro flush mount ?View attachment 117394
There is enough room but it might require extra clearance behind the bumper. I don't recall exactly whats tucked behind the bumper. The flush mounts require clearance behind the rear of the housing. Any pics of exactly where you're trying to mount will be appreciated
Loufish
Burbank CA
I love my XL80s and lower grill light bar kit. I modified my grill and extended the light bar so it sits flush with the grill opening. The lumen output is awesome.
So after exposing your 10" bar you got a fair amount of light back?....I ask because that's my plan...
Big Blue
Administrator
Staff member
Admin
USA
I got it all back, there is zero blockage. You loose around 30% behind the grill.
Cuzin Eddie
St. George, UT
I installed my BD’s for my back up lights and the driver side is rubbing on the exhaust. Does anyone else have this issue and what was the fix? Bend the light bracket?
Speeddeacon
NC
Looks like the exhaust isn’t mounted symmetrically. Don’t recall if there is any adjustment to the exhaust mount or not, but I would look into that first. How did you even get the light mounted in the bracket with that little clearance?
Cuzin Eddie
St. George, UT
I had my son pull on the exhaust to give enough room to get it screwed in. It was a SON OF BEE!
