Speeddeacon
So help me with this one guys....I installed the Pro light kit and was running the harnesses. I saw CJ you tube video and tried it his way. Needless to say I will find another route more like Speeddeamons. So I ran the 55inch splitter over the skid plate as CJ suggested. So no power wires were connected...None. When I snugged the harness up above the skid plate smoke SMOKE!!! So much I could not see the wires form the top. WTF. no Power connection was every made to the battery. The splitter harness melted. Hot!! burn you hot. What the heck did it contact and even if it did find something all the wires are coated and double protected. Baja Dude said maybe hot exhaust but the truck hadn't been running in two days . Any ideas ?
You are saying that the only connection was at the lights and no upfitter/power connection? So no power connection and a cold engine? That doesn’t make any sense at all. There had to be a heat source, whether mechanical or electrical. The wires are insulated, but not to exhaust manifold degree of temps, by the way.
I’m not familiar with CJ install method, but my 55” harness ran from upfitters to passenger side fog pocket. There wouldn’t be enough length to run across the skid plate so you must have an additional harness I’m assuming.
