CGERM
Thank You and Krazy House Customs in New Jersey!
Be advised I have a set of the pros combo in white and a set in wide cornering in amber. Just show your friend this pic.
---------- Post added at 10:00 AM ---------- Previous post was at 09:57 AM ----------
Also loving my new rear baja lights! Pair of Squadron Sports and a RTL-S
No it's there. It's actually one of the first options listed here: Vehicle Specific: Ford - 2017-2018 F-150 Raptor - Headlights & Fog Lights - 4x4TruckLEDs.com
It's actually the 1st and 2nd listing on our site.
Dual kits: 2017 Ford Raptor Dual Fog Light Bezel Kit - 4x4TruckLEDs.com
Triple Kits: 2017 Ford Raptor Triple Fog Light Bezel Kit w/KC HiLITES Flex Lights - 4x4TruckLEDs.com
Check the signature![]()
looks good, i'll probably go with a set of sports, don't do much backroads driving so i think the sports will suffice.
Yes you can. Thanks to Baja Designs' uService, you can pull the face plate and rotate the lens and replace.
Just make sure not to over tighten the lens and make sure that the gasket is properly in the channel so it doesn't get damaged. It's not hard, you just have to make sure that everything is lined up properly before you tighten it.
If you do over tighten, you risk cracking the lens or damaging the gasket which can cause water/condensation intrusion into your light.
Laser Lights at KOH !!!
Come by the Baja Designs booth at King of The Hammers (KOH) and check out the latest in high performance lighting! We aren't talking Halogen, HID, or LED... Baja Designs has NOW introduced Laser Technology. The Laser Light is capable of throwing light 60% further than LEDs!!!
OnX6 10" Hybrid (LED/LASER) - $999.95
https://www.bajadesigns.com/products/OnX6-10-Hybrid-Laser-and-LED-Light-Bar.asp
With the extreme amount of distance being achieved we have created a "Hybrid" light in order to give the user the ultimate package. We utilize Laser and LED chips wrapped in our high speed spot optic to deliver a smooth blend of light for less driver fatigue. If you're looking for a light that will cut through the night with ease, look no further.
QUANTITIES WILL BE EXTREMELY LIMITED - CALL TODAY TO RESERVE YOURS - 8004225292 - ETA: MID 2018
We will also be introducing an XL Laser Light! This will be ideal for applications requiring auxiliary lights for maximum distance. Stay tuned for more details and information!
www.bajadesigns.com
