Baja Designs: General Discussion Thread - GEN 2
Baja Designs
Baja Designs
Installed the full complement of BD lights for the Raptor. The ambers in pockets are covers but the OnX6 has an amber lens.
Looks fantastic! Thanks for sharing!
-Bailey, Baja Designs
www.bajadesigns.com
---------- Post added at 08:56 AM ---------- Previous post was at 08:39 AM ----------
The LP9 just got a little bit BOLDER!
Introducing a new, more aggressive, cast housing for the LP9. One of the noticeable changes is the larger openings for the Direct Ducted Cooling at the top and bottom of the housing. This will increase airflow to the light and in return keep the light cooler allowing everything to run at peak performance longer. This housing also features a sleek black powder coat finish. Take a look at the website for more pictures and information!
https://www.bajadesigns.com/products/LP9-LED-Auxiliary-Lights.asp
Post up if you have any questions! Don't forget to save nearly $60 per LP9 with your forum discount. Coupon Code: BDForums
www.bajadesigns.com
Jtnuge
That is one sweet looking light. Just wish I wanted cowl mounted lights. I will be purchasing the fog light kit from BD as soon as the weather turns warm.
Baja Designs
Baja Designs
Awesome Raptor rocking our Plug and Play, Fog Pocket Kit!
(courtesy of Instagram.com/trevor_evox)
Take a look at all of our 17-18 Raptor Lighting Solutions
https://www.bajadesigns.com/products/Ford-F-150-Raptor-17-Lighting-Kits.asp
www.bajadesigns.com
---------- Post added at 01:56 PM ---------- Previous post was at 01:53 PM ----------
Thanks! What version are you going with for the Fog Light Kit?
Sportsmen
Pro
Umlimited
If you have any questions regarding these 3 options feel free to post up!
www.bajadesigns.com
Jtnuge
I was leaning toward pro at first. Then I noticed the s2's on the unlimited had more lumens. I want to have those for lighting up the shoulder of the road. I'm curious about the mounting of the lights on the bracket. I have seen some that look like the light that is close to the center of the truck is cut off. Your white truck on the site looks great. There is no cut off of half the inner light.
Baja Designs
Baja Designs
That is correct - The Unlimited Kit will have the S2 Pro (2,450 Lumens ea.) vs the Pro and Sportstmen having the S2 Sport (1,130). This will make a noticeable difference in cornering and comfort lighting.
Sometimes the inside lights can appear cutoff depending on the angle of the photo. This is how the setup should look all mounted. If you were to stand another 10-20 feet back it would appear in full view:
4x4TruckLEDs.com
Jtnuge we can built you a customer kit if you like as well. A lot of folks want to get the Pro kit but want to go with S2 Pros over the S2 Sports, so we can make those adjustments before you before we ship them out. Just let us know and we can design a kit for you with the lenses/lights you need. We've done it for a buncha folks on here.
