Baja Designs: General Discussion Thread - GEN 2
raptor36
Well, hopefully we hear something within the week. Fingers crossed.
MJK
Designed from the ground up our new S1 fills the shoes of a large light in a small package! The S1 utilizes a highly specialized reflector and LED combination to outshine the competition. With the 2.1" length, width, and height the S1 is highly versatile for any application that is in need of light. Whether you're looking for a light to drive off of, or something to light up a campsite the S1 will exceed your expectations!
Specifications:
Lumens: 2,375 Utilizing 1 LED
Wattage/Amps: 20W / 1.45A
Dimensions: 2.1" x 2.1" x 2.1"
Weight: 0.4 lbs
LED Life Expectancy: 49,930 Hours
Front Lens: Hard Coated Polycarbonate
Housing: Hard Anodized & Powder Coated Cast Aluminum
Bezel: Billet Machined Aluminum
Hardware & Bracket Material: Stainless Steel
Exceeds MIL-STD810G (Mil-Spec Testing)
Built-In Overvoltage Protection
IP69K (Waterproof up to 9ft & Pressure Washable)
IK10 Compliant (Mechanical Impact Testing)
CLICK HERE
Would this wire directly to the switches or battery?
raptor36
THE OTHER product
srey89
Baton Rouge, LA
I know it's prob been discussed on this thread but after skimming through, I couldn't find an answer. I want to add some lighting to my 19 but don't want to break the bank. Light output wise, am I better off going with the s8 kit or the pro fog pocket kit?
4x4TruckLEDs.com
I'd say go with the Fog Kit with Baja Designs lights. You'll honestly get more for your money as you get 3 pairs of lights. Regular fog lights for everyday use which will be awesome and then some additional off-road lighting.
Our Baja kits are located here but if you PM us we can help you out with anything you need: http://www.4x4truckleds.com/led-auxiliary-lights/baja-designs/raptor-2017-lighting-kits/
You can also "make your own" kit on our site as well. Shoot me a PM and I can help you out.
Nick@Apollo-Optics
It depends on your needs. Do you need more distance lighting or more overall coverage?
If coverage, the fog kit. If distance, the 30" S8 will outshine even the Unlimited kit due to the higher mounting position.
Happy to help go over more options with you to get your setup dialed in. Please let us know if we can help.
