Baja Designs Fog light install
2014RubyRed
Galesburg, IL
I would get some of that plastic loom material and wrap those single wires up in it. You'll be surprised what can get crammed up in between the skid plate and frame. Truck looks good though......
crash457
crash457
I'm Batman
St. Louis, MO
Good idea. I used the last bit of flex loom that I had in the garage to cover the wires as the ran up the core support and under the hood to the firewall.
TKS
San Diego, CA
Just did the install today. Took longer than I thought it would, but VERY happy with the final product. Wiring length was just fine. Since wiring layout was not included in the kit, I just did a mock layout in front of the truck and that helped me determine where everything should go.
TIP...install black powder coated mount first. Then, take the lights off the silver brackets. Then attach the silver bracket to the black powder coated bracket. I found this to be MUCH easier. Then attach the lights back onto the silver brackets.
Good luck everyone! Great product @BajaDesigns and thanks for hooking us up with a great deal via the group buy and great customer service @Rick@FreedomMotorsports!
Mark986
I installed all lights on the mount first then installed the mount. Worked like a charm. Some of the allen bolts are a little difficult to get to and tighten, but it worked out.
Jetsco
I finished my Baja Designs fog light kit install tonight. The brackets are really well made, lights are crazy bright and the install definitely took me longer than I thought it would. However, it was worth it as I couldn't be happier with the final outcome! I did spend the time and unscrewed each lens cover and turned them so that the labels were upright and I also flipped around the small individual light mounting brackets on each light which pushed the lights closer to the front of the bumper opening which I preferred (just personal preference).
Thank you to @Rick@FreedomMotorsports and @BajaDesigns!
S2 Sport wide cornering on aux 6
Squadron Pro Driving combo and Squadron Pro spot on aux 1
Photo #3 - head lights only on.
Photo #4 - head lights and S2 wide cornering on.
Photo #5 - head lights, S2 wide cornering, Squadron Pro Spot and Pro Drving combo all on.
consolidated
Thanks for this tip, I tried it and like this look better. Also using the slotted holes to move each lamp into place. It may lessen beam cut-off and spill behind the bumper.
Agree with others here that mounting the lights to the bracket first is easier, especially if you replace the button head allen bolts with regular stainless bolts, and they're harder to strip, ask me how I know.
Mark986
Glad I wasn't the only one annoyed by the upside down lettering lol.
TXCobra
Question, the S2's obviously go on the outside corner, but did you put the driving / combo in the center and spot on the inside or the other way around?
