Baja Designs fog pocket install
MDJAK
NY
flipping lenses void warranty? If so, what about changing out amber lenses for clear?
4x4TruckLEDs.com
Correct - on the sae it voids the warranty - that’s why we stock the lights with the lenses already flipped
badclam
PNW
Good reason to go with Diode Dynamics in that spot. I can't believe BD wouldn't warranty their product for a simple lense change, they sell lenses? I've bought several gen 3 fog light brackets from you, and for my Braptor, and have always used DD lights there. I like to buy the 3000k yellow lights, put a clear lense on them to give me a 4000k light. My personal favorite color for rain. I do run BD XL80s for my main go fast lights, which are 5000k, which is far better than the normal 6000k lights found on most companies "white" lights. The brackets from you, and wiring harness, are the best I know of for the raptor.20220918_124729.jpgBRAPTOR23.jpg
4x4TruckLEDs.com
Good reason to go with Diode Dynamics in that spot. I can't believe BD wouldn't warranty their product for a simple lense change, they sell lenses? I've bought several gen 3 fog light brackets from you, and for my Braptor, and have always used DD lights there. I like to buy the 3000k yellow lights, put a clear lense on them to give me a 4000k light. My personal favorite color for rain. I do run BD XL80s for my main go fast lights, which are 5000k, which is far better than the normal 6000k lights found on most companies "white" lights. The brackets from you, and wiring harness, are the best I know of for the raptor.View attachment 472765View attachment 472767
Correct. On the SAE lights only though. Baja states that these lights are aimed at the factory and to maintain their SAE rating if a customer takes the lenses out they can risk messing up the pattern.
Diode Dynamics SS3's are mounted from the center, so the lights can be oriented properly since the pivot point on the light is centered.
badclam
PNW
Now I know why. Thank you.
Anything coming anytime soon for the Raptor Ranger fog light hole beside the small OEM replacement?
4x4TruckLEDs.com
All we have is our dual Baja designs kit - you can technically install our triple fog kit but the front parking sensor won’t work as there’s no place to reinstall it
