aux wire 1
gdof15
Highly recommend SVP harness extenders. Ford buried aux switch wires so you have to pull battery tray to access. SVP extensions are well made and numbered so you can easily change what's wired to each switch in future if desired
Specialtyperformanceparts
u realize there r 6 up fitters and 1 extra on the headlight knob makes 7 . Ive never seen an amp rating for the headlight knob ,were is your source ,I can find the 6 up fitters no problem .
If you are asking what the amperage is for the OEM fog button on a Gen 3 Raptor, it is a 10-amp fuse.
Please feel free to call or text us if you have any other questions we can assist with.
Thanks!
Sidney @ SPV Parts
(317) 934-6778
[email protected]
swoop1156
USA
My source is my highly intellectual brain and the ability to remember things. I read it here on the site somewhere and when I get some time I'll search it for you.
swoop1156
USA
Antho
@greatone99 The factory fog light circuit is not on its own fuse. So i cant really say what the amp rating would be. The factory Fog light circuit that is powered by the Fog switch is FET protected at the BCM. So the BCM will shut the circuit off and throw a DTC if its not within the factory fog rating. I would say as long as you stay within the factory rated fog spec you should be fine. I wouldnt put much on it.
The factory fog connection and Aux 1, both of which are separate connections that are tied into the bumper on the Gen 3 Raptor, are both maxed at 10-amps each.
Hope this helps.
Thanks!
Sidney @ SPV Parts
(317) 934-6778
So-Cal-Al-52
I Love Fossil Fuel
San Diego
I agree, When I was in there fumbling around for my Aux 2 switch wire I added these to all the Aux wires ,so future instals will be much easier. Cheap to buy and easy to crimp on.
G
greatone99
ma
sounds good , I want to to use the fog button for my Baja design squadron pro
I think they draw 3 amps each . Then aux 1 and 2 for wide cornering and 2 for the spots
4x4TruckLEDs.com
where is aux wire one located ?I assume its in a different location since its being used
If you have fog lights from the factory, then Aux 1 is connected to one of the Rigid lights.
If you don't have fog lights from the factory then Aux 1 is in the upfitter bundle next to the battery. It's tucked/taped inside the fender area. Remove the battery for easy access.
You can easily extend these wires. A few wire connectors and then whatever connectors you want to use (DT, WP or even some others on the market). We usually do this for local customers so that when they come back later for more lights, we don't have to remove the battery again.
But if you are looking to re-use Aux 1 for something, we make some pigtails that plug right into the factory Aux1. Keep in mind you will have a connection on the passenger and driver side fog light area.
We make a few different pigtails:
CrystaLux DT 4-Pin to MX150 Pigtail, Pair (2021+ Ford F150 & Bronco Raptor Fogs)
https://www.4x4truckleds.com/crysta...gtail-pair-2021-ford-f150-bronco-raptor-fogs/
CrystaLux DT 2-Pin to MX150 Pigtail, Pair (2021+ Ford F150 & Bronco Raptor Fogs)
CrystaLux WP 2-Pin to MX150 Pigtail, Pair (2021+ Ford F150 & Bronco Raptor Fogs)
You'll be fine running our WP 2-Pin to MX150 Pigtail for a pair of Squadron Pros. One on each side.
We also sell complete fog kits and brackets as well if you (or anybody else) is interested in upgrading the factory fogs and/or adding fogs:
https://www.4x4truckleds.com/vehicle-specific/ford/ford-f-150/2021-f-150-raptor/fog-lights/
G
greatone99
ma
I already extended the wires aux 1 and factory fog button wire
