GEN 2 Aux Switch wiring when over fuse Amperage?
sixshooter_45
Arnold
wheelman55
Big Bend or MN
Great, thanks. I'm near St. Louis.
I noticed that it is only rated at 13 Amps, however, I believe the first two high lifter switches are rated at 15 Amps.
Six shooter...wire your lights up to a RELAY. The relay does the heavy lifting amp-wise. The switch just “switches” a small amount of current to the relay. The relay sends the current to the load.
Check into the Tony Candela link that I put in post #10.
sixshooter_45
Arnold
Good link, thanks.
wheelman55
Big Bend or MN
Here’s a pic of the aux and pass through wire bundles with the Deutsch DT 6 position connectors on my 2018 Raptor. The relay in between the bundles is for the backup lights. If you look close you can see the Hellroaring battery isolator at the far left that I used for their dual battery system.
