Army Testing the Future of Off-Roading Tires?
John M BUNMAN
BUNMAN-Adventures, Rescue & Recovery
Las Vegas NV
melvimbe
No way these show up on Raptors, not close to their current state anyway. Article said nothing about what sort of weight load they could handle or the speed rating...but the fact that they are testing on a Polaris instead of a heavier vehicle says a lot. Of course, they did say that it's a very uncomfortable ride.
Wondering if there is much point of using shocks on this, since it seems the 'tire' gives before the shocks. Perhaps if you've compressed the tire to the point where all the tire material is compacted to the wheel...then the shocks would be useful.
John M BUNMAN
John M BUNMAN
Las Vegas NV
All good points. I did see them somewhere before on a larger vehicle. They are definitely not speed rated. It would probably be a miserable road ride.
By the time you add 4-Operators, Delta. Seal, Ranger, SF or PJ’s and their kits I’m sure the Polaris will be exceeding its weight capacity lol.
I’m thinking their main goal is durability in several operational environments. Those boys can’t afford a mission delay due to tire failure.
Maybe a smaller run flat like what’s on the Hummers?
John M BUNMAN
John M BUNMAN
Las Vegas NV
These have been around for quite some time. You can get them for a lot of commercial equipment. Horrible for the general consumer industry as they have an exponentially higher lifespan.
Ok, now I’m reminded where I’ve seen them I think. Do some folks put them on Bobcats or something similar?
melvimbe
I know nothing about Army operating procedures, but assuming this is trustworthy, perhaps they would put a 4 man team on two vehicles, or something of that nature.
Seems like it would be rather difficult to find material that has similar mechanical properties to compressed air, but not actually be a gas or liquid. Only a completely solid setup would avoid the issues they are trying to eliminate. Of course, a track system does that.
Would it make sense to have a pretty much solid rubber tire with a rather sturdy shock setup to smooth out the ride and reduce damage to the tire? I guess no, since that's not an offered solution.
