Anyone using the Rigid Extended Brackets to flip their fogs?
Phil O
Sacramento, Ca
According to Rigid's warranty posted on their site that voids the warranty.
That does void the warranty. There could be leaking. Also, many companies out there offer only a 2 way plug kit for the harness when you actually need a 3 way plug kit. The reverse mounts at SpecialtyPerformanceParts are only $66 for the 3 sets.. I also opted for the 3 way plugs for my wire harness and the owner, John Trischler, also installed the plugs to my lights for me prior to shipping.
Brett 2019
Springfield,Pa
I’ll be attending 3/28-3/29. Pictures below post. Using bracket you ( spv) provided as extra. Lights don’t wobble. I lined them up shining lights on garage door.
Specialtyperformanceparts
ok no worries. It may just look different because the Sideshooters are wider and you have them on the outer most position. They fit a little better on the most inner position. No big deal though. It’s just what you prefer.
How was the install overall? Was it fairly easy?
Brett 2019
Springfield,Pa
Install was easy, especially using your custom harness. Only one pair of radiance and two “D” series. All lights work. I tried using my 5 amp (6th switch ) to hook the backlight . I hooked white wire from light to white harness wire both sides. Can’t get the backlighting to work. It’s already tied into ground used in custom harness ?
Based on what you said, I would guess the fuse for the switch got blown. The fuses for the switches are under the hood behind the battery. It’s easy to blow the 5 amp ones. Especially if you tried one of the higher power lights on it. If you didn’t get the $15 backlight wire kit, that makes it very smooth without using any switches.
L
ljn21
Tega Cay, SC
Sent you a PM!
