GEN 1 Anyone running the Gen 1 Eibach front springs?
Hasty
Hasty
San Marcos, CA
I emailed Eibach for some additional info on Monday. I have yet to hear back but will update if I do.
Jd400
West Texas
Not to try to get the jump on you, but I called Eibach earlier today. They did return my call just a bit ago.
I was told (by a very helpful and courteous gentleman) that their springs are about 10% higher rate and a bit longer than the stock springs. They are not quite available to the public, but they should be very shortly.
I’m interested and curious about running these in the bottom perch for mid perch heights and bottom perch ride.
Also, I’m new here and a new (to me) Gen 1 owner. I’ve been scouring the forum and net for upgrades. Mine appears to have been stock for the most part.
Hasty
Hasty
San Marcos, CA
This is great info, thanks for reaching out! I too am looking for mid-perch height at bottom perch ride. Currently on the Geiser wait list but then saw these as perhaps another option.
tltoronto
toronto ontario canada
I think the main issue on these springs would be the amout of lift they provide. +3 is a lot for the front cv's to handle. It will be an interesting comparison between those and the Geisers. Gotta say, the Geisers on low perch are pretty amazing.
meatmark77
Lompoc CA
I just got off the phone with Eibach and was informed that the springs are a progressive rate, they are about 10% higher rate than stock as mentioned above. I was curious about the +3 and was informed they were designed off the bottom perch and this spring would make the truck sit level with stock rear suspension. I run a +3 Atlas and with the shock set on mid perch the truck would sit level. I will be placing an order for them through my job. I will report back with on-road and off-road feedback.
93,363
56,644
LDMiles
