Ytown
Yuma, AZ
Installing Eibach 1” front spring tomorrow. Have the option to purchase rear springs also if wanted but am on the fence. Long term I want to get 37s under my Gen 3 2023 35. I am trying to confirm i can fit 37s going this direction with minor trimming if necessary. This is a daily driver with little load ever put on it, every so often maybe a boat or trailer traveling less than 50 miles from current location. Anyone got any pics of this already?
Sig Fanboy
WV
You do not need any type of lift to put 37’s on a 35 so long as you use the factory offset wheels I can tell you from personal experience.
Possibly other offset wheels will work also, there are hundreds of posts on this forum on the subject.
I will likely lift mine in a manner yet to be determined as I think it would look better. I have 37 Nitto’s, which are closer to a true 37 than the BFG AT’s. I have not gotten any “ air” with the truck but can assure you there is no rubbing whatsoever for normal day to day usage, even turning the wheel sharply crossing a dip.
Ytown
Ytown
Yuma, AZ
What offset are you running with. I have +6 ordered currently scheduled for install this Saturday
