Ruger
The beauty of the internet: Everyone you meet on the internet is an engineer, scientist, lawyer or law enforcement professional. Or all of the above.
Or a sasquatch hunter!
(Hee-hee)
Nope. Facts are facts. This is not about opinion. Do your own research, IDGAF what you think.Gotta be a dem... you're right and anybody else who thinks otherwise is wrong.
Zero benefits. In today's computer controlled (ECU) cars, using a lower thermostat will just confuse the car thinking it isn't all the way up to temp possibly leading to premature fouled plugs and/or O2 sensors. There is no reason to change the stock thermostat.
https://blog.viscosity.com/blog/bid/372966/heat-exchanger-velocity-why-should-i-care
Careful, lots of math in this one
https://www.ripublication.com/ijaer18/ijaerv13n14_04.pdf
moving fluid through a heat exchanger at a faster rate = lower temps... is that the jist of it? With no regard to fluid volume? With no regard to the efficiency of the heat exchanger? With no regard to ambient temps, surface area of the heat exchanger? Just pump it through faster...
You being an ME doesn't mean anything to me as you clearly don't know what you are talking about on this particular subject. That is what is comical. Just admit you're wrong and move on, no big deal. And your summarization of my 'thoughts' (they aren't thoughts, they are facts) is wrong, clearly you missed the point where I said 'all things being equal', faster flow rate through a heat exchanger is always better - key words here are all things being equal.Comical my friend. You link some thermal dynamic info and think it describes how a cooling system works on a car. I suppose you think these links would also suffice in a AC discussion? Fact is, I am an ME (Mechanical Engineer to you), math is my strong suit. Iv also worked on cars for 20+ years and just about anything else mechanical or electrical.
So to summarize your thoughts... moving fluid through a heat exchanger at a faster rate = lower temps... is that the jist of it? With no regard to fluid volume? With no regard to the efficiency of the heat exchanger? With no regard to ambient temps, surface area of the heat exchanger? Just pump it through faster...
Let me guess... couple years out of school... no real work or life experience... just academic?
Right, because we all know how flexible Republicans are in their opinions. Science much?
