I still have my truck.
He meant mrpositrac
He meant mrpositrac
Damn that's no good.
I know I have a 6.2 but let me tell you I have been through this with my 6.2 Chevy. The tune is what makes the engine perform and THERE ARE A LOT OF OTHER THINGS that have to be taken into consideration as well. There are so many parameters that can be tuned or have to be tuned like when you go from reverse to drive and you are not at a complete stop the engine will stall if the idle is not set perfectly to account for the small momentum of the truck when the forward gear engages. Slowing down quickly on the freeway in traffic, stop and go in traffic so the truck will not lurch. Fixed that on the Chevy by adjusting leaning out in that condition. The transmission is also involved because the engine programming can make it do thing you don’t want as well.
It took 10 test drives with the laptop hooked up during 4 of those to get it perfect. You can keep all of the super chargers because there is nothing like a tuned truck with the right exhaust, medium lope sitting at a stop light sitting at a stoplight! That cam got a the truck a lot of looks and questions. The Raptor set up that way would be just sick!! I am waiting on work to be done with the tune so I don’t have to do it all myself!
correct me if i'm wrong but wouldn't a cam from ford racing keep the warranty intact? or is that just a crazy wish? i love the sound of the hot rod cams and i'm seriously considering pulling the trigger on it
My hot rod cams are going to come out when I get my new long block. I'm almost positive Mrpositraction sold his truck because of all the driveablity problems he had with his truck because of the JDM tune.
If I don't trade to a 2013. I want to put a high compression 2013 GT500 short block with a good set of ported 3V heads so the hot rod cams wouldn't be enough.Why are you taking out the Hot Rod cams? And what would replace them?
1000 crank hp on NA. Good luck on this sohc, 2-valve mod motor.
