Anyone here running Roadmaster Active Suspension?
WoahItsRob
Virginia
I recently installed to help raise the back end up to reduce sag under acceleration and towing. I haven't noticed any/as much wheel hop on highway speeds going around a sharp curve and hitting a rough road patch so thats a big plus. All in all, I'm happy with the purchase and ease of install. I'd recommend it, but don't do any hard core off roading
Sent from my SM-N986U using Tapatalk
C
Cody Templeton
Des Moines, IA
I'm sure I'll end up going with it. Roadmaster said they'd give me a returning customer discount as well, so that's a bonus.
Ski4Ever
Denver, CO
WoahItsRob
Virginia
What's the part number of the kit you ordered? Is this it? And if so, did you get the standard or heavy duty kit? Please follow up here (in this thread, preferably) once you've got it installed to let us know what you think!
https://activesuspension.com/products/kits/2009-2016-ford-f-150-supercrewext-cab/
Thats the one I grabbed in the standard. Didn't even know there was a heavy duty version lol
My back end is sitting at 43 and 1/8th inches from the ground to the fender well. Eibach springs in the front have me sitting at 42 and 7/8th inches
I used the black shim on the RAS
C
Cody Templeton
Des Moines, IA
2691 is the correct part number for the 10-14 Raptor. It bolts under the U-bolts rather than around the spring pack like the normal F-150's. I called Roadmaster to verify for sure I was ordering the proper kit because if I could have I'd just have pulled the kit off the 13 Limited to use on the 13 Raptor. There's no option for a heavy duty kit for the Raptor, just standard.
I also ordered the ReadyLift 3" OE-style rear blocks as well. I'm currently 1" lower in the back than the front. The 3" block should give me about 1/2" more height, and then I'm expecting the RAS should give about 1-1.5" based on my install on my 13 Limited. I want to get about 2" out of the back so that it sits just a bit higher than the front.
Ski4Ever
Denver, CO
Ohhh, I didn't realize you had Gen-1 Raptor. Yep, according to the Application Guide, 2691 is for the Gen-1, and 3611 is for the Gen-2.
