The operating strategy of the 4WD system changed in 2019.
Due to concerns with IWE (Integrated Wheel End) disengagement on cold starts, Ford revised the TCCM (Transfer Case Control Module) and PCM programming to keep the front hubs engaged until the truck is fully warmed up. This prevents the hubs from partially engaging after a cold start due to lack of sufficient vacuum. There is a software update that is available for earlier models as well with the same strategy.
When 4A is activated, the front differential is engaged with the transfer case, regardless of how little torque it may receive based on conditions. I wouldn't rely solely on the depiction in the Instrument Cluster to determine where the power is actually being routed.
I've had 2 F-150s with the Torque-on-Demand T-case...a 2018 Powerstroke Diesel and my 2019 Raptor. Haven't noticed any difference in the way either drove when in 4A, except the extra traction available.
