And so it begins......
BaseModelRaptor
DFW
Not sure if this was asked …did you calibrate with forscan for the change in tire height?
BaseModelRaptor
DFW
I did some reading and looks like you had the dealer put on wheels and tires so they probably recalculated for them. No surprises but that would make @lawraptor hypothesis wrong.
lawraptor
Northern Nevada
It actually doesn't. How does that fact make my position wrong? You're not even on 1st base bud. Everyone's running circles around you.
What does "recalculating for them" mean? You're clueless.
BaseModelRaptor
DFW
So you asked me what something means and I’m clueless?
I rest my case.
W
wreckitshaw
Tampa
No the truck was not recalibrated for tire size. I spoke to two different techs as well as a tech they flew in from the southeast region from ford. The tires had absolutely nothing to do with the fault in the IWE and hub system.
They told me it was faulty from the factory, hence the reason the regional tech came in.
BaseModelRaptor
DFW
Nice but the recalibration would definitely improve drivability. I immediately noticed shift points being off before i recalibrated. I’m surprised or maybe I’m not that the dealer didn’t do this as part of the swap.
At least you’re fixed now.
W
wreckitshaw
Tampa
Truck drives beautifully. The dealership used a third party to do the work. They warrantied it and sold it to me.
I've done forscan for the speedo and other things. Maybe I'll look into tire height.
