^post#8 says he doesnt like cup holder lighting at all, he wants footwells
I've been thinking about using the ford led's , I have a bunch from other projects but I've never been sure of the voltage? Are they 12v or 5v?
gotcha
Single color Footwells :
Mutli color footwells:
They're 12V.
Thanks, but I already have all the OEM LEDs and the trim panels that they were installed in from another F-150 that came with them. The OEM LEDs are all multi color; they use one ground and three power wires (red, green, & blue) and use these three colors to give you a total of seven available colors (red, green, blue, cyan, magenta, yellow, & white). I was only planning on applying + 12V to the blue wire, but if you have a controller that would work with these LEDs for a color changing effect, I may be interested.
I played around with these a few times using a 10V DC power supply and I'm sure I connected the negative lead to the black wire and the positive lead to one or more of the R/G/B colored wires. I'll double check on Monday though.
gotcha
Ambient Footwell lights - $33.24 : The Double AA, Corvette and Camaro Modification Products
Multi Colored Footwell Lighting - $114.00 : The Double AA, Corvette and Camaro Modification Products
I confirmed today that there is a positive wire for each of the LED colors and one ground. The wire colors correspond to the LED color (red, green, blue) and are labeled R, G, and B on the board. There is one brown wire for the ground and it's labeled GND on the board.
What all is included in the single color kit? Are you able to dim these at all?
