Alternator upgrade?
dewalt
They warn you about charging a agm battery with too high an output, as battery is sealed. Most hydro chargers have an agm setting. With the old lead acid battery you had to sort of match your alternator to your battery size. Too small a battery and too big an alternator shortened the life of the battery. Or so it seamed. So that is why I was asking
J
jabroni619
Interesting. Perhaps there is a phenomenon going on that I'm not aware of.
dewalt
How do you wire in a winch so reg knows to put out full charge for winch?
The Car Stereo Company
here, on frf
generally a high output alternator wont do anything to your battery because it is going through the voltage regulator/rectifier. connecting a charger straight to the battery bypasses that so too high of a charge can damage your battery
UncleBruce
Don't forget your winch has a circuit breaker. I tried to winch myself out of a river bottom and immediately blew the breaker. Wouldn't have gotten out without a snatch block to double the pull and reduce the load on the winch. Battery wasn't a problem.
J
jabroni619
I thought of that too. I'm considering going with a 400A fuse instead and keeping a few extras in the truck. I also have a snatch block.
