On a side note I do wish Brembo would make a kit that would fit under 17s.
I'm sure a 17in kit exists is some fashion. Though you probably need to hand select the necessary parts to make it.
That being said, I want the Alcon's in a bad way. But I can not justify spending 6k on a brake upgrade. And even if I did spend the money for a BBK that wasn't the Alcon's I would still be upset that I then have to buy new wheels. In all likelihood I will just buy one of the rotor and pad upgrade kits once I figure out which has the best performance and the least dust.
I had to buy new wheels to clear aftermarket UCAs anyway. And RPG confirmed that their kit clears Weld 17s.
I think the Alcon kit is really nice but I didn't want to use spacers and I didn't want iron calipers. Only thing I'm disappointed in with the RPG/Baer kit (so far, since they aren't on the truck yet) is that the rear rotors don't have aluminum hats. I'm debating trying to see if the RB rear rotors will work but I'm hesitant to mess with this kit as designed.
Also, if you're going to have some extra weight, low down and in the rear is where you want it.
Sir, you own my desired wheels. I salute you.
Where did you find them?
And where did you find that Baer Kit? I don't see it on the RPG site?
We should talk wheels and power mods. Mostly wheels though.I had to buy new wheels to clear aftermarket UCAs anyway. And RPG confirmed that their kit clears Weld 17s.
I think you're limited on Baer, because you're keeping 17" wheels ... most 2pc require at least 19" wheels
I had the Baer Extreme+ setup, two piece rotors with aluminum hats but I'm a self-loating street donkey putting 20-22" wheels on a Raptor
Seems to be plenty of room for that in the front, where they provided aluminum hats and 6 pot calipers vs. 4s in the rear. I actually think they went with all iron rotors in the rear so they could reuse the stock drum type emergency brake. RB uses an iron sleeve inside their aluminum hat to allow the OEM emergency brake to be reused.
https://www.racingbrake.com/RB-Rear-Two-piece-rotor-for-Ford-F-150-p/2571.htm
Anyway, 37s on 20s is realistically going to be more than enough side wall for most Raptor owners. I actually did debate getting 20s so I could run the Brembos (and 325/60R20 Duratracs, which is an awesome all around tire and a very practical 35.6" tall) but at the end of the day I just didn't want to take the risk. I love the way my truck rides and handles on 17s at relatively low psi.
