GCATX
King Dingaling
The horns go on the roof, like a man!
I’ve had my Hornblasters Nightmare Edition kit mounted on the spare tire delete bracket for about a year and a half. Best decision I’ve made since taking my Gen 2 home from the dealer. Spliced into OEM horn and through AUX 1 switch. Press the horn on the steering wheel and you have their attention. Flip the AUX off and it’s your regular horn. To date the switch has never been back in the off position. But yes spare tire is mounted flush in my bed under the hard tonneau cover.Has anyone installed an Airhorn on their gen2? I have the retrax bed cover and thought I could mount compressor under the bed cover container and also use it as a regular compressor but where would you place the horn setup? I have an add stealth fighter bumper
Bad ass turbo bro..I relocated the horn into the engine bay. A train horn is a bit extreme for me.
I got this:
I have my compressor & tank mounted to the frame (no drill even) under my passenger side. Been on there for over a year and have had it buried in mud many times, used its skid plates/brackets to scoop up mud while burying it, covered in salt (from road and salt flats), drug thru the snow, & sand blasted running thru the desert at high speeds and it just keeps on running. Kleinn makes a compressor/tank combo minus the horns, or with horns. I went without horns.Now, I’d like an undercarriage air tank for the setup but again I’m concerned about how much of a beating that would be able to take.
To prevent chafing I always use cream when I’m polishing my horn.Yikes. You can’t have stained horns, so in that case you would definitely need to polish your horns. There’s probably some cream that would help rub that stain right out.
the hornblasters kit i have is metal. havent seen plastic ones unless they are the cheap onesI had the Kleinn 730 Demon Train horn kit on my '17 Raptor. I upgraded the compressor and upgraded from 1/4'' air line solenoids to 1/2''. It cost me over 2100$ for the kit. I liked them better than the Hornblasters kit I had on my F350 since the Kleinn train horns are metal and not plastic. I have them for sale on offerup if anyone is interested. Only installed on my truck for less than 6 months with zero issues. Like new condition.
DIRECT FIT TRAIN HORN AND ONBOARD AIR SYSTEMS FOR 2017-2024 FORD F-150 RAPTOR SUPERCREW
Equip your Ford Raptor SuperCrew (2017-2024) with Kleinn's Direct Fit Train Horn and Onboard Air System. Engineered for off-road dominance and superior sound.kleinn.com
