Aftermarket Wheels
josh34
Stuart, FL
Apologies if this has been discussed...
If you get TPMS from tire rack, do they still show the individual tire pressure on the dash (within the vehicle settings)?
You need to be sure which TPMS your truck uses, there are different models with different frequencies across the Gen2 years. Best bet is to have one pulled to check. if not, your as built data will show the frequency and you can id it from that.
If you get the right TPMS for your truck, you’ll get all 4 tires showing psi.
tone228
Do you know what info from the build data? I was going to order a set of sensors online but it says I need to go to the dealer to get the part number first.
I don’t. I went to it today to check and did not find it. I believe I originally found it on etis.ford.com which is dead now. I think some years have only one TPMS, but the 2017 had 2 with different frequencies based on build date. I have the early MY ones. A Ford stealership might be able to help.
