Aftermarket Wheels
NJSP117
New Jersey
[/COLOR]Wheels are + 6 offset.
I had trouble finding lugs. These were super cheap but great quality. Paint did not chip off at all with install.
https://www.amazon.com/dp/B01BGIF054/?tag=fordraptorforum-20
Bought the Wheels from Mr. Wheeldeal. $879 including tax and shipping. Shipping only took 5 days from the day I ordered.[/QUOTE]
So, am I correct in that a +6 offset pushes the wheel 1.1 inches or 28mm further out than the stock wheel?
Pacific Wheel
Reno, NV
So, am I correct in that a +6 offset pushes the wheel 1.1 inches or 28mm further out than the stock wheel?[/QUOTE]
You got it.
NJSP117
New Jersey
You got it.[/QUOTE]
Great, thanks! I actually like the stock beadlock wheels, I just wish they sat a little further out. Is there any way to use a spacer? Or is that dangerous? Or does it cause problems? A 1 inch spacer would do the trick, but I'm thinking the lugs are too long anyway....would need to be 1.5 inches and I think that's too far out.
Pacific Wheel
Reno, NV
You got it.
Great, thanks! I actually like the stock beadlock wheels, I just wish they sat a little further out. Is there any way to use a spacer? Or is that dangerous? Or does it cause problems? A 1 inch spacer would do the trick, but I'm thinking the lugs are too long anyway....would need to be 1.5 inches and I think that's too far out.[/QUOTE]
No real way around unless you use an adapter and trims the tips of the factory studs off. I usually don't recommend adapters but if you were inclined to buy a set, I'd talk to Lenny at Motorsport Tech. He makes forged steel adapters for Ford F450/550, Dodge 4500 etc... trucks to run semi wheels so I'd imagine the strength is there but they're also heavy. I'd pick Lenny's brain and see what he says. He's a personal friend and good dude. He'll be straight with you. He is insanely busy though so expect to hold if you call him. 775-351-1000
