Aftermarket Wheels
GR8Ride
Upstate New York
I have asked as well- twice. I got crickets!! Lol!
Also wondering what other changes will we need to do to replace wheels with 20” size other than recalibrate speedo.
brettmess24
Only if you go 37’s on 20’s will your speedo be off enough to matter. You can get 35x12.5R20 and they will be close to stock height.
You can run them with stock suspension and 35”.
Not sure what the backspacing is on the black rhino wheels but if you plan to run 37’s in the future and or upgrade UCA’s, shocks etc stay around 5-5.5” backspacing.
GR8Ride
Upstate New York
Thanks this helps a lot! What would be needed to get the ties to poke out from the fender by about an inch?
I like the look of the white raptor in the photos in this thread with the Black VR 601 wheels.
Thanks all in advance!
brettmess24
The 601 and 602 have 5.5” of backspacing on a 9” wide wheel with +12 offset. So look for a wheel with similar specs and don’t forget about the wheel width.
PandaSnapp
Sumter, SC
I want new wheels on my 2018, but wish to keep with the BFG stock tires. I think these will fit the current tires, but I'm hoping someone here can say for sure, as the dimensions are a bit different than the OEM.
These are the ones I'm looking at:
https://www.americantrucks.com/mick...o-4-black-6lug-wheel-17x9-0418-f150-ford.html
  • Dimensions: 17x9 – Front or Rear
  • Comes with a 6 x 5.31 Inch Bolt Pattern
  • Features a +18mm Offset Size
Also, with the +18mm offset, what will that effect?
Thanks much.
Members online
95,395
58,940
tony66ptr
