Aftermarket bumpers
OffroadAlliance.com
Boston, MA
How much weight are these adding. Are you seeing worse mpgs, sag front or back or are they about the same weight as stock. I assume heavier and yes to all the above.
Most of ADD's bumpers are pretty similar to the OEM in weight. Even if it was, lets say, an extra 90lb...think if it as having a teenager in the front seat. Even if you added a car full of people, you don't typically notice. So adding the weight of a heavy teenager to the front of your truck is little to no difference.
ATXraptor75
Austin, TX
Have SVC's newest bolt on bumper OTW and should arrive on Friday sometime. This is pre-powdercoat. They include the ACC bracket and I added a light hoop to install four BD LP4's. Sensors are built into the bumper and have ability to install 6 Squadrons or one 20" in the center area.
What model is this? Their primary Baja... doesn't look like the smurf from Gen2
QCRappy
Charlotte, NC
Gen3 baja bolt on
