DozerEO2
Recently I installed the aFe Power Momentum XP Pro cold air intake. The installation itself went off without a hitch. After giving the truck a few hard runs I noticed the absence of any turbo noise. I decided to check under the hood and low and behold the filter had been pushed completely into the filter housing! After thoroughly checking all my connections, the only thing I could think of was that the coupler to the passenger side turbo was too long. I've been in constant contact with Michael from aFe, who's been awesome to deal with thus far, and got permission to trim the coupler down by a half inch at a time. I'm at 1 inch at the moment. Has ANYONE come across this problem and if so, what was your solution? Assuming you found one. I have considered a bellows type coupler but have been told that the nature of the bellows slows the movement of air and that they only use them when absolutely necessary.....which I'm beginning to think is the case.
Any thoughts or suggestions, other than returning to stock, are immensely appreciated!!
Just a quick edit: The photo's below are of what happens after driving hard, NOT the completed or correct install.
