Hello everyone,
I’m seeking your input to see if I’m over thinking my situation and making it more difficult for myself.
I installed the ARB dual compressor behind the rear seat. There is a T-fitting to allow a hose to run to the couplers mounted on each side of the rear seat.
The issue I’m having is the plastic hose keeps popping out of the T-fitting. I make sure the hose is inserted far enough to where you can hear it click but it will only stay in place for a few seconds. Wife hates having to hold the hose in the t-fitting because it gets pretty damn hot. She‘ll kill me if I ask her to hold the hose the next time I use it.
I ordered the reinforced hose along with the JIC 4 Adapter T thinking this would be an easy solution.
Unfortunately, the T adapter doesn’t fit in the compressor because the outlet is an NPT fitting. Looking online, I have not been able to source a Male NPT to female JIC 4 adapter for this adapter Tee to screw into.
This is where my head is at…
1) figure out a solution to keep utilizing the plastic hoses. Any suggestions?
2) continue my hunt for for a Male NPT to Female JIC 4 adapter.
3) source a male 1/4 NPT adapter Tee with two female JIC 4 outlets.
Option 1 sounds like the easiest?
TIA.
Steve
TIA.
Steve
