ADD Phantom Front Bumper Question
ToadSmasher2K1
Home Is Where You Make It
Red Kingdom
It looks like that video shows how to recalibrate on Forscan. It's pretty easy. I did have to do it two or three times before it stuck, had no problems after that.
GEN3LV
Las Vegas
I am going to pull the grill off and make sure its set correctly and see what I get if no go I will recalibrate with Forescan. Thank you for this info I am pretty sure I can work it out with this Tech Info.
ToadSmasher2K1
Red Kingdom
I did my calibrations on the highway. I believe you have to be going 30mph or above. The highway also gives the sensor more readings off other cars, if that is in fact what it’s looking for. Who knows
Good luck
k9ltd3
california
I'm about to install mine as well on my 24 with the honey badger bumper with upper loop. So I need to mount in the top position. I have seen several posts saying to angle it down a little. Has anyone measured the exact angle of that? Just want to get it right the first time so I'm not having to keep taking things apart to adjust.
