ADD "ed" pro bolt on front bumper + BD lights
smgilles
smgilles
Did you relocate your ACC? And if so what bracket did you use? Im about to install mine and i got the BajaMod ACC bracket but cant find any install guide or write ups from folks who have done it.
I do not have ACC on my 802A.
Tomhorn
St david
I would be careful putting anything there if u havent relocated your turbo intercooler even front plate blocks it ****** placement. I have a 14 which light bar is great there. 19 i got 42 “ bar from f150 leds and set up 3 fogs sae white amber infared be careful of the intercooler is my only advice theg run hot
Gaptor
Denver Colorado
I have 0 problems with my intercooler and heat soak. With the CVF I run about 25 degrees over ambient at a cruise.
Gaptor
Denver Colorado
Overall it was an easy install even by myself. It's a clean and simple design. Fingers crossed it doesn't rust..... I still haven't figured out how to attach my front plate (swarfworks vs 3M tape?). I had the fog lights set up with spots, driving combos, and S2's, so wiring already in place for adding the amber driving/combos. I moved the S2's to the rear.
I used black zip ties to hold it to the add cutouts on mine and looks fine
smgilles
smgilles
Thanks for the plate ideas guys! Also, my Whipple IC runs much cooler than previous stock IC too. I measure temps via COBB AP.
Donovan
DC
Good to know that people have a nice looking aftermarket front bumper without having to relocate the FMIC.
That is another few hours of work.
What other bumpers can be used that doesnt require FMIC relocation?
chi_weezy
Well-Known Member
I’m also about to install this bumper. Figured I’d throw in the CVF IC while I was at it. Tackling this project soon
