How To Add cooled seats
FAMARO
Katy, Texas
Can we use the newer factory cooled seats and just plug into our existing wires? Or is there more too it?
Trevor*
Trevor*
Phoenix, AZ
All the parts I used are the ones that come on a 2012 or 2013. Which existing wires would you connect to?
AUH1
Abu Dhabi, UAE
Trevor thanks for the write up. Any chance you can list the parts you used? I would probably go with replacing the seat cushion instead of modifying. I have a 2010 with heated seats.
Also would you be able to point me to somewhere online to get the parts as I'm located outside the US?
Thanks!
FAMARO
Katy, Texas
Thanks!
I also have a 2010 and dont know what will interchange?
DieselD
Arizona
I have been wanting to go down this road myself. Here in AZ cooled seats are the shit in the summer! I had seen the ducting in the floor and knew I could buy the ducting,blowers, and cushion foam. I however want to go one step further and get the switches in the dash just like factory. It would need some programming but should be able to use the as-built data from a 2012 with the cooled seats and get it to work like factory.
Trevor*
Trevor*
Phoenix, AZ
I ordered from this web site: TascaParts.com
Here are the part numbers on the boxes.
Lower blower - 8A5Z-19N550-B
Back blower - 8A5Z-19N550-A
Ducts used in 2nd option
BC3Z-18D507-A
BC3Z-18D507-B
AUH1
Abu Dhabi, UAE
BC3Z-18D507-A
BC3Z-18D507-B
Thanks Trevor. I take it I will need 2 of each if I want to driver and passenger seats. Also what about the seat cushions? Are there specific part numbers for them?
