Now that I'm mid-perched, I wanting to regain some of the factory rake back, but I also want a little more additional payload/towing support.
I know the initial response is to go Deaver, National, etc... however, it seems many of the aftermarket spring packs have had some unhappy customers, sagging due to leaf fatigue, cracking, and the re-arching maintenance...whereas a few folks that just added a single leaf between the #1 and #2 factory springs have all been satisfied for their needs.
And to be quite honest, I'm not spending $1200+ for a bundle of metal springs...I just need a little support in the rear, not an entire makeover. My Raptor is 99% highway use, and will probably not see any off-road use for many years (I have another F150 and Jeep for trails and slinging mud). I'm basically asking to see how many folks have gone the Add a Leaf route and what the long-term issues (if any) have been.
This is what I'm looking at...
Kit # 0910F150XLKIT3A contains:
2 SXL-4310 Double punched Extra Leaves
4 HC-11 Handy Rebound Clips
4 UA601S U-bolts w/deep nuts & thick hardened washers
4 CB-1550 Center bolts with nuts
Kit cost is $163.60
This kit is to install an extra leaf on each side between leaf #1 and leaf #2 of F150 2WD or 4WD pickups with OE 3 leaf springs. The result is 800lb of increased spring capacity and 1+" of increased rear height. Installation involves removal of old u-bolts and center bolts and drilling the rivet on each rebound strap to remove the OE rebound straps and provide a recess to index the handy rebound clips provided in the kit.
There is also another kit that adds a .807" spacer for a little extra height...
Kit # 0910F150XLKIT3A+S contains:
2 SXL-4310 Extra Leaves for Between Leaf #1 & 2 of 3 Leaf OE Springs
4 CB-1550 Center Bolts
1 pair of 0910F150SPACERPLATES
Kit cost is $199.20
This kit is a extra leaf to go under leaf #2 of the 3 leaf OE with a .807" spacer plate for under each spring pack to gain additional height. Because leaf #2 on the OE 3 leaf pack has rebound straps attached installation involves drilling the rebound strap rivets to remove OE straps and provide an index divot for the provided Handy Rebound Clips. This kit will increase load capacity by 800lb and raise rear height by approx. 1 7/8" .
There are several additional options listed on their website, up to 3+" and 1k additional payload: HUSKY SPRING Suspension Solutions
Kit cost is $163.60
Kit cost is $199.20
