Adam's DAILY SPECIAL - A new deal each weekday!
AdamsPolishes
AdamsPolishes
How many oz dose it take to foam a raptor
About 2 ounces in the container, then fill the rest of the way with water. With a Raptor, you will likely use the whole foam gun container in one wash.
-Dan
Wilson
South Dakota
I have a presherwasher with th soap thing yep fill it with straight soap.
Also would allperpose cleaner take off hydronic oil off my tractor, if I put it in the washer?
TheWolf
Spokane, Washington
Wilson, do you have a foam cannon or are you using the soap reservoir that is part of the pressure washer?
Amazon.com: Professional Foam Lance Adjustable with 32 oz. Bottle: Health & Personal Care
The soap reservoir on a pressure washer does not work very well, as you need to have air added to make foam, which is what the MTM Foam Cannon does. The Adam's Foam Gun also adds air to the water/soap mix, but it can be used on a garden hose (no pressure washer required).
For your tractor, start with a pressure washer rinse, then spray full-strength All Purpose Cleaner on the oily areas and scrub with a brush, then rinse with the pressure washer.
Putting the APC in the pressure washer soap container or in a foam cannon would dilute it too much. On hydraulic oil, you need full-strength.
When using All Purpose Cleaner on paint, make sure the surfaces are not hot, work in the shade, and do not let it dry on the paint. Work small areas; rinse, scrub with APC, rinse, move to next section.
Wilson
South Dakota
You know how big a tractor is lol this is going to suck dad dowced the whole thing. At least I have one of those dule action pump bottles
Yes it's a presher washer it dose fome it up good but I'm using full stiranth
AdamsPolishes
AdamsPolishes
Wednesday 10/21
Adam's Tire Shine 16oz with free Half Moon Sponge for $9.99 before the forum discount.
If you have not tried the Tire Shine yet, it looks great, lasts through repeated washes, and seals up the rubber which helps keep the mud from staining your tires.
The Half Moon Sponge applicator works good on some tires, but the Pro Tire Hex Grip Applicator works really well on tread block like the stock BFGs. For more aggressive tread blocks, use the Trim & Lug Nut Brush for spreading the product out after spraying it on. Just make sure you don't leave excess product in the blocks or any lettering, as it can sling if left pooled up.​
Yukon Joe
Trafford, PA
Wednesday 10/21
That's an expensive nut brush!
Yukon Joe :baby: :baby:
