Those look Hot Greg, Just do both.
Greg,
to run 7 D2's on one uplifter switch would that be possible? if so which one?
I am seriously considering doing this
After some suggestions I went back and whipped up another "incredible" photoshop...
Using 6 4" 50-WATT SOLSTICE PRIME LED LIGHT both 20 degree and 40 degree lights... With an aproximate 25,800 lumens (each prime is rated at 4300 lumens) Each solstice prime has 5 10 watt led for a total of 30 10 watt leds..
Mounting on the upper grill there is only space for 6 4" led lights because of amber lights and grill supports.. Would be able to use factory mounting points for the grill with minimal amount of fab work (metal and tabs) to make it work..
Comments, suggestions, etc welcome...
this one kinda looks like butterflies on the front of the truck..lol
Nice work Greg! I'm wanting to do something different and still keep the clean stock look of the truck. I'm thinking the 6 up high would be the best...then 2 more on hood mounts just in case![]()
While I like the first idea better this might be the best way to go because of the added weight of the lights so far from where the grill brackets bolt to the hood. Unless you are planning on making a reinforced grill mounting bracket... The weight added to the grill is my only concern but, I really like the concept!!! I think it looks sweet and stealthy looking...
How much does each light weight?
