850+ whp F150 Ecoboost (CRP Upgraded Garret Turbos)
thatJeepguy
GA
Great post! You didnt mention any upgraded cooling?
zfgracing
zfgracing
Like engine cooling? It's all stock except for the t-stat and a coolant pressure sensor. Haven't run into an issue with cooling on these. You guys gotta remember it's a 21 psi cooling system water doesn't boil until 259 degrees. People freak out when they see 220-230 after hard pull, those are normal temperatures for these things. In fact you won't even get a coolant warning until closer to 250. The big thing you want to watch out for is if the temperature doesn't drop back off after a pull.
