5x7 JL C5 570 speakers from The Car Stereo Company!
here, on frf
ok bird. bad news. they are not the same. i just pulled my door panel off.....again..... and found that the plugs are keyed differently, and opposite. meaning that the male and female side of the plugs are switched on the tweeter.
trayack
Nantucket, MA
Whats the RMS of the factory amp?
Also, is there really any point running the supplied JL crossover? The factory proscessing is going to kill the levels and freq's regardless....
Just thinking, because I MAY end up putting in my Pioneer c720-prs' that came from my other system. Don't have the coin right now to do the JL Cleansweap, amps, Sub ect...
Now if my Zapco C2K's fit, maybe that'd be a diff story.....
Harblar
Aberdeen, SD
No idea what the factory RMS rating is, but it ain't much... they're claiming 700 total system power for everything, including the sub. Divided evenly that's 87.5 watts of "peak" power per speaker, though your probably looking closer to around 70 watts per speaker and 200 for the sub. My guess is the actual peak power is less than that, with RMS being considerably lower.
Not sure what would be a good replacement for the speakers just running of the factory amp, but I'd find ones with low power ratings (under 40 RMS) with high efficiency ratings. That would likely give you your best bang for the buck.
If your using the factory amp straight to aftermarket speaker, then any passive crossovers supplied with the speakers would not be needed as this function is handled by the factory processor and individual wires are run from there to the woofer, tweeters, etc... in fact, doing so would about guarantee that either the woofers or tweeters wouldn't work, depending on which set of leads you attached to the passive crossover.
Hope that helps. :biggrin:
BIRDMAN
BIRDMAN
Birdministrator
Boston
Thanks Harblar, similar to what I've done in the past I will dive in head first, document the process along the way with plenty of pics and report my findings with a review. We will all know the answer by tomorrow night.
Sent from my thumbs using Tapatalk 2
Wilson
South Dakota
don't forget the string that's important won't work with out it, and don't cheep out buy the good stuff it's well worth it.
Harblar
Aberdeen, SD
I prefer 50lb monofilament, myself. Combine it with a large coffee can and you got some hidef audio right there, I tell you hwat!!
Hahaha...
