BigBlackRaptor
Thank you for your insight and response!Yes, because they’re connected through the differential.
Not likely, as the front driveshaft spins freely in 2WD. So no transfer case engagement.
So that’s definitely an issue; the axle should spin freely with vacuum applied. However, if one IWE is damaged and stays engaged, it may cause drag on the other axle.
For one thing, you should NOT engage in 4WD at highway speeds on hard-surface roads, PERIOD! This is per the manual, which explicitly states that it "can produce excessive noise...". So you've got two significant factors that could cause the mechanical issues you're describing by driving at excessive speeds beyond the design of the 4WD system, and while driving on dry pavement. Sounds may be more pronounced when turning the steering wheel, even the the slightest turn. Remember: we have 4WD and NOT AWD, which the latter is designed to operate at all times and conditions, on all types of surfaces.
Right. I never use or engage 4wd at highway speeds. Maybe I should have clarified that I slowed down to about 30mph when the noise started and engaged 4wd for the sole purposed of seeing if that would stop the noise and it did make it stop. Otherwise I would never even be moving when engaging 4wd, let alone doing it at highway speeds.
I'm really new to all this, but I'm having a similar but less violent issue. Could it be that the IWEs aren't properly engaging and disengaging even with the right amount of vacuum just because they (or something connecting to them) needs to be lubricated?
Yeah it seems possible. I replaced an IWE years ago and did quite a bit of research on the correct procedures on how to do so. And @FordTechOne stated the same things earlier in this thread.
In any event, if that procedure is not followed correctly, that seems like it could cause problems and it seems that is probably the case with me. I had work done to the truck a short while ago that required removing the IWE and putting it back on but not replacing it with a new one. Possible it wasn't done correctly.
All of this to say, I am having both IWE's replaced today and will be sure to report back with my findings!
Thanks again everyone for all your help and insight
