37's on OEM Tires (2017 or 2018 Gen 2) Anyone?
T
Tlh235
the ol' grammar mistake...i see what you did there...a tire can't fit on a tire.........you sir win the internet for today.
BBLV
Newport Beach
I have Geisers and+3 Deavers, just put on 37x12.5x17 Toyo RT's, but with a lower offset than OEM (+0, 17x9 wheels). I rub slightly on the back/inside of the front wheel wells. I don't intend to cut a thing and by the look of it I can probably get away with some heat gun bending/massaging of a little plastic. At factory offset you may not even rub - it'll be very close.
TXRaptor
I also have Geisers, Deaver +3s and 37x12.5x17 Toyo RTs on a 17x8.5 rim with +6 offset. (factory is +34 offset which will be just over an 1" further in than mine) My fronts were rubbing slightly on both sides at full lock so I had to cut a 1" square of plastic from the inside of the inner fender well. I might do a little more in the future, but in the 200+ road miles since trimming, I have not heard it rub.
Crooked photo due to tight spot to take pic! (You can still see it...) :smile:
